A famous prophet once said: "Can we all get along", then they burnt down the city.
I thought this would be a project to try on my EWS Rev 11- 211D. Please refer to the earlier posting of the first page of this thread. Different revisions of the EtherWave Standard over the years may have different and unexpected results. Time will tell… Someone knows the revision turning point for this project to respond properly.
I need to put in a Mouser order for my other project and being this project is 90% Radio Shack would like a stock of the little caps in order to mail out all 4 if wanted along with an un-etched copper clad board cut to size at no charge. It is all about theremin advancement.
I “give away” many things theremin which encourages bulk buying. About the EW: 15 pf capacitors C2 & C6. Would you rather use 4, 18pf or 4, 15 pf. These would be 5% COG. It is my feeling you had the 18 pf lying around or is this 15/18 combo an engineer thing? (-‘ It will take me a few weeks to get to my EW. I am actually a little excited.
dewster said: +/-12V and ground are available at the 8 hole inline expansion point on the Etherwave, and this is where I located the prototype board. C6 and C2 were removed from the EWS board with a solder sucker and iron, the capacitor legs were then bent outwards 45 degrees, so that they form a 90 degree angle with each other. One leg of C6 A was then resoldered at the position where it came from, in the hole closest to the edge of the board, with the free leg of the capacitor pointing towards the prototype. Same for C2 C (solder it into the hole closest to inline expansion point).
… B to the free hole at the C2 location (closest to the center of the board). Because these capacitors are directly connected to the sensitive side of the LC tanks you'll want to keep these wires short and direct.
![](http://www.oldtemecula.com/theremin/tw/ews-bb.jpg)
PDF 116k
