"I'm still holding out for magic as well, but this was just too easy...." - w0ttm
Yes - "too easy" always worries me! ;-) - I think "if its that easy, why hasn't it been used / done extensively before?"
Not to say that one should write-off "easy" solutions - but caution is probably advised.. For example, the "RCA Switch" on the Theremax is an "easy" "solution" - just switch a 100k resistor into the circuit, but to my ears, its sound is nothing like the RCA. (on this matter, I completely disagree with Uncle Howie!)
I have not really tried to recreate the RCA sound - my focus has been on pre-mixer processing, using additive techniques to allow adjustment of each harmonic and craft whatever waveform one wanted, with frequency dependent control over the harmonic profiles - this (in theory at least) should allow any sound and behavior of any theremin (including the RCA) to be accurately emulated..
But it is complex - If a simple post-mixer circuit can do a reasonable job of replicating the RCA sound, then this will certainly have a place and be a lot cheaper.
As I see it, the Lev theremins had/have two main desirable features - First was/is playability and linearity.. I believe that the secret of this has now been revealed, and can be replicated with the simple circuitry which has been published here on TW - Simple Fet oscillators which actually have the same topology as Lev's original oscillators.
The other feature was / is the tone.. If this turns out (and its starting to look like it might) to be simple, then the job is done - only the volume circuit / VCA remains to be finalized, and the RCA's volume circuit is bloody awful - no problem in bettering it!
I suspect that an entire theremin design for a reasonable solid state RCA "clone" which is simple to construct with low cost, readily available parts, could easily be completed this year - IF there is no "magic" we have yet to discover.
