"In simulations at least, this oscillator loads down at antenna resonance a lot less than any other I've simed, including uncle Bob's EW." - Rob
Yes - The Lev oscillator is (IMO) a superb design in every way - the series configuration means that loading only occurs across one inductor, one half of the total tank inductance.. As far as I can see, this means that stalling the oscillator, or going close to "the edge" is unlikely if not impossible.
I think that this does mean, however, that the playable span is reduced - the "virtual inductance" imposed by the resonant antenna circuit is only seen across 1/2 of the tank inductance, rather than the whole tank inductance as is the case with other theremins, so the change in tank resonance frequency applied through this mechanism is self limiting.
but are more than 3.5 octaves really needed? - I think probably not. If one is looking to construct a RCA "clone" (or more ideally, a ClaraMin Clone) then I think we stick with the Lev oscillator.. I think that this is by far the easiest way to implement a theremin front-end that promises good linearity. I would suggest that even if one doesnt end up with a RCA sound-alike, this simple oscillator / antenna circuit is an ideal basis for whatever theremin one develops - Probably ideal for home constructors and "newbees".
