"Bob Moog noted in his "repair notebook" concerning Clara's Theremin that he found amplitudes of about 70Vpp (this version of the document mentions even 100Vpp)at the grids of the mixer tube." - Thierry.
Oh, I do hate it when people take a comment entirely out of context. - What Bob Moog also wrote in his notes was THIS:
" Early theremins use the venerable 24A as a mixer tube. Here is where the audio wave is synthesized. "
Bob says quite a bit about the operation of the mixer, and its effect on the waveform:
"The mixer tube is biased beyond cut off even though its cathode is grounded. Bias is obtained not only from the large negative peaks of RF voltage applied to the 24A grids, but from a steady component developed in the cathode circuit of each HF oscillator. The RF sine wave fed to each grid is very large -on the order of 100V p-p or more. Only the peaks of positive voltage are large enough to produce pulses of plate current in in the 24A. This plate current forms pulses corresponding to the frequency difference between the two HF sine waves. The magnitude of the high frequency pulses, but not the steady component of the bias, is determined by the pot adjustments. Therefore, it is a complex system, because turning either pot not only alters the magnitude of the synthesized audio frequency, but its waveform. The RCA theremin is very similar in this regard, but lacks rheostat adjusters."
And not a single word about how the transformers "create" the waveform through "impulse response" - In fact, not a word about the transformers influence on the sound at all.
Until proven otherwise, I will take the word of someone who has actually examined these theremins, someone who grew up with tubes, who had unquestionable competence, whos analysis makes technical sense.. over yours.. Particularly as this person wsa Bob Moog.
"It seems clear to me that the output waveform can not be a sine wave "
I dont think anyone has said it was - I certainly havent.. What I have said is that I believe that understanding the mixer, and the WAVEFORM PRODUCED BY THE MIXER, is of paramount importance - You, on the other hand, have effectively declared that the mixer is of minor importance, and that the waveforms are "created" by the transformer charactaristics.
But this is really getting pathetic - I have said all along that you MIGHT be right, I have not said you are wrong, I have simply presented my analysis and declared my uncertainties and admitted that I am out of my depth. However you have not, IMO, given me any reason to accept your statements as absolute truth, you have given me no reason to think that you actually know what you are talking about..
What you want from me? Faith and worship ???
Lets wrap this up.. My last words to you on this matter (I hope):
I disagree with you on the following:
"don't waste too much time with the 227 and 224 tubes as I did.
The secret of the waveforms is elsewhere in my opinion."
"And I continue insisting on the fact that the oscillators, the mixer and their waveforms are only of secondary relevance, the "magic" is in the impulse response of the audio transformers."
"The transformer's impulse response makes the waveform."
But I fully accept that the charactaristics of the components following the mixer (including, but not limited to, the transformers) could - no - will - have a profound effect on the final audio output.
My plan and stratergy has been clearly stated - I believe that, to "clone" an RCA or Claramin, the waveform from the mixer should ideally be crafted to match that of the output waveform from the 224 mixer as closely as possible, and from this starting point, following circuits devised which behave in a similar way to the circuits following the 224 mixer.
Our major area of disagreement appears to be that you believe a transformer is required to produce the waveform from the mixer - I fundamentally reject that idea.
