Dewster,
John, I've noticed quite good stability over voltage for common base Clapp, and believe this spec is important for overall stability. My favorite is common source Clapp, which oscillates almost no matter what. Have seen quite low current draw with common emitter Colpitts, 0.3mA including buffer!
I appreciate this advice, and whatever else you feel like telling me. I'm solid on the theory, but am lacking in practical experience with theremins. If there's one thing repairing guitar amps has taught me, it's that experience counts for a lot.
I tried out tube Clapp oscillators in the common-anode configuration, which is like common-collector or common-drain in the solid state world. They worked well, and I almost used them in my first build. I was using capacitors of 56pF (the "Clapp" capacitor), 680pF, and 2000pF, with a 2.5mH RF choke as the inductor. With the pitch antenna directly connected to the 56pF capacitor (no antenna coil), I got good range and linearity -- both in simulation and in a real circuit. But, for various reasons, I ended up going with the cathode-coupled oscillator.
That said, I don't believe there is a "magic" oscillator out there that impacts linearity in any significant way, and that the search for it is a canard.
I agree with that 100%. The frequency is determined by the total effective L and the total effective C. The rest of the circuit really doesn't matter. My simulations taught me that pitch linearity depends on (1) how the capacitance varies with the distance of the hand -- which depends only on the antenna geometry, and (2) the relative sizes of the C or L in the oscillator on the one hand, and the effective C or L of the antenna + hand on the other hand (no pun intended).
Have you considered air-core for the series coil? The ferrite cores you are using are likely the main source of whatever small drift you are experiencing.
Thanks! I did not know that, and now you've got me interested. I chose the RF chokes because of their flexibility. How do you make it all work with an air-core coil? Do you just make a coil of about the right inductance and then tweak the oscillator frequencies to make it all work?
One thing I'm concerned about is the self-capacitance of an air-core coil, which is quite a bit larger than that of the RF chokes I'm using. It seems like the additional capacitance would diminish the sensitivity of the thing to hand movements. Any thoughts about that?
John
