Hi,
I've already played a bit with electronic (designed 5-6 PCBs wth mcu, soldered 0.5mm 32 pins mcu), but have almost zero experience with analog electronic.
I'd like to build a theremin where the electronic components are visible. I'd like it to be either air wired (either something similar to [url=http://www.homebuilthifi.com/project/2165]this[/url] or using a DIY [url=http://www.americanmusical.com/contentpages/012315_marshall_handwired/images/fig5.jpg]tag board[/url] made from wood and brass tubes.
Is it ok to do a theremin like this, or is the placement and shielding of electronic components too critical to try this ?
Is there a schematic you would recommend me ? (My alternative is to buy a paia kit, so I guess my budget is about $150 for electronics. Bonus point for the schematic if I can use an external PSU, but I guess for low component count and good sound, most schematic will be lamp based and require 300-500V ?)
Thank you,
Jaune.
