Hi Roger,
I just removed the pitch axis 1.999mH inductor from the prototype and tried to measure the SRF. I did this by setting it on a tall plastic box, driving the lower end with a function generator set to sine, and measuring the field near it with a test lead clipped to a scope probe placed a few inches away from the coil but otherwise unconnected. I scrunched the top unconnected lead of the inductor down to make it physically small and less antenna-like. Ground for the setup was provided via the scope. This is a rough-and-ready setup somewhat similar to one described in a paper I read by Knight, though he used antennas on both ends (as stimulus and sense) with no direct connection.
My function generator doesn't go above 2MHz, but resonance was clearly somewhat above this as I had to bring my hand ~1" or so near the top end of the coil to make it fully resonate at 2MHz. So I can't really measure anything beyond L via my LC meter and DCR via my DMM for the pitch axis coil.
I took a couple of similarly constructed coils on my bench with larger inductance values and so was able to measure the SRF and Q at resonance:
L=3.813mH, DCR=92.8, SRF=1.488MHz, Q=148 (squat aspect ratio)
L=6.186mH, DCR=74.2, SRF=1.164MHz, Q=166 (tall aspect ratio)
I measured Q by finding the -3dB (0.707) voltage point on either side of resonance, taking the frequency difference, and dividing the SRF by the difference.
Could it be that I'm doing something wrong in the measurement department? If not, then Q might actually be higher than this because the function generator output impedance is 50 ohms, which is damping things somewhat. And SRF would be a bit higher if the free top lead were clipped shorter.
Because Q is a direct multiplier at resonance, Q's a bit greater than 100 are consistent with the AFE drive voltage (+/-1V square) and the voltage seen at the AFE capacitive divider (1:100 sine). I don't know what the Q of the antenna intrinsic capacitance is, but I believe it isn't excessively damping things when no hands or such are nearby.
IIRC I've had less luck measuring the SRF and Q of Bourns 6300 series chokes with this method, I don't know if it's the ferrite containing the magnetic field more or what, but they don't seem to generate as high voltages at the scope probe at resonance, and their resonances are broader. Just seeing several of them in series inside the EW tells me their SRF and Q probably aren't all that hot.
[EDIT] Just measured a Bourns 6310 I had laying around:
L=51.04mH, DCR=111.3, SRF=479.4kHz, Q=60
Not too shabby. There may be something wrong with my methodology, but it's testing like this that drove me to single layer air cores.
"I just happen to have 3 full cabinets of Coilcraft non-RF inductors..." - pitts8rh
Your place sounds like an EE heaven! :-)
"If the pitch extension arm becomes electrically part of the pitch antenna, I can generally feel it, not because I have any great sensitivity but because of the way I play."
Yes, I've often thought that the geometry of the pitch coil placement might be somewhat obvious to some players. This is one reason I place the coil smack dab in the center behind the plate, and likely why Theremin placed the coil below and on the same axis as the antenna. His "Enron" case further ensconced this arrangement artistically.
[EDIT2] Interestingly, if you work the LC resonance equation backwards to calculate the parasitic C of the coils I measured, my two air cores work out to ~3pF, and the Bourns 6310 works out to 2.15pF. I know that "interwinding" C is likely an incorrect way of imagining / calculating parasitic C, but I believe the larger C of the air cores is due to the larger "plate area" of the high-Z business end windings acting like one side of an intrinsic capacitor with the environment. It certainly behaves that way, and isn't necessarily a bad thing if properly integrated into the physical design of the Theremin. And I assume the Bourns Q being ~1/3 that of an air core is due mainly to magnetization losses in the ferrite, though I always wonder to what degree the ferrite "looks" rather like a shorted winding to the coil?
I must say, the exquisitely sensitive and highly interactive nature of the Theremin has given me intuition (however incorrect) into capacitance and inductance that I likely never would have obtained elsewhere.
