In that case, I'll just stick to 12 VAC instead of 14 or 15 VAC.
Isn't breadboarding a method that invovles no soldering and a completely different type of circuit board? I know that I'd need to solder the connection between the components and their respective clips, but do you solder the buss-wires between clips? How would this be done without clips (just wondering, I'll use the clips.)? Would the buss-wires be connected from component to component without the use of connectors?
In the previous thread, we discussed what pots to use. You said you used much cheaper ones with a 1/8 watt power rating. Your power source was +/- 5V, and mine is +/- 12V. Will I need the 2 watt pots listed, or could I use the same ones that you used?
