"Fred, if you find any circuit giving any better linearity than another I'd be interested in the details. " - dewster
Not seen anything which betters yor polynomial corrected results.
I do know that linearization does occur, in practice, when on has a "correctly" tuned antenna working with a "correctly" tuned tank.. I would be forced to acknowledge this even if the only "explanation" for it was something from celtic mythology ;-)
When it comes to simulating this, I have never been able to get absolutely convincing results. I believe that factors such as arm capacitance must be responsible for the better "fitting" I have seen - that, in fact, one may find if one got a perfect psreadsheet result, this would not equate to perfect actual linearity... Not unless one included these other factors in the calculation.
Other factors which really make matters worse can be the proximity of the theremins ground contributing to the total hand capacitance like a 2 plate capacitive sensor does.. Good grounding (or lack thereof) which makes the players coupling to ground insensitive to change in their ground goupling as a function of proximity, probably contributes more to linearity than anything else could.
Sorry - got interrupted and had to post quickly... I continue:
I have certainly seen definite effects on linearity as the result of changing the EQ inductance and matching the tank to "correctly" interface to this.
The best "playground" for this was with my H1 theremins - Linearity was not a primary objective - they werent at all bothered by this, and I chose the EPE-2008 front end which was supposed to have better linearity than the standard SC which had no EQ coil.. All this EPE design did was tack a coil onto the SC front end.. It was abysmal. I first used cheap inductors, then changed these to good inductors - no difference (except for lower thermal drift) - In fact, removing the EQ inductor made virtually no difference to linearity - in some cases the linearity seemed better without EQ.
Then I modified the tank drastically - tacked another inductor in parrallel with the primary inductance (tacked it across the IFT) to reduce the total value, and added a capacitor to bring the frequency back to that of the reference oscillator (which I didnt change), and changed the series blocking capacitor to adjust sensitivity..
The difference in playability (which I am sure was due to linearity) was astounding ... But I never actually measured the linearity - I did all this quietly and "secretly" while the show was going on, taking each theremin in turn and swapping the modules and antennas (to which the EQ inductors were bolted) - Fortunately I had designed the theremins so that it was easy to swap things (the theremin itself was in a tabbed plastic box that fitted into a cutout in the speaker enclosure, and could be removed with 4 screws and one connector, and the antenna assembly lifted off after removing 4 screws, and contained the inductor and a magnetic connector which self-located to its mating magnet)
It took me days to complete the modifications on all the theremins I had parts to modify (10 of the 16) - I was able to compare modified and unmodified theremins during that time, and my belief that the modified ones were far better was "confirmed" by the couple of people who came every day to play, and who chose their favorite theremin, always from the modified ones..
Then, one morning, I came to the show and powered up the theremins, and they were all terrible! - in fact the unmodified ones seemed more linear than the modified ones. By lunch time, after having removed some modules and antennas, I was at my wits end - they behaved as they should.. But put them back into their boxes and they were cr*p.
The electrician came over to me as I was miserably eating lunch and proudly told me that he had tidied up (removed) my ground wires.... ! ..... Back when I was installing the theremins, none of the specifications had been followed, so I wired up the power and seperate ground wires as best I could... with wire reluctantly given to me by this electrician who told me I was doing everything wrong.. I had wanted (specified) for each theremin to have a seperate ground wire going back to a common ground point.. but there wasnt enough cable, so I was forced to daisy chain them...
The theremins interacted like hell, and I ended up cutting the ground wires leaving a gap of about a foot - these became "ground antennas" which had enough coupling to the structure of the hall to provide a good ground field, and by disconecting the common (galvanic) grounding between the theremins their interactions dropped from being impossible to being "occasionally bothersome" between only two theremins.
"thanks" I said, LOL - I was so relieved that I didnt even feel angry - I put some aluminium foil connected to the ground inside the plinths the theremins were standing on, and everything worked again.
At that time I had never attempted to simulate EQ response accurately - I thought that I understood the EQ mechanism, but actually my understanding was shoddy - Before I got into debugging the EPE I really didnt have a clue.. If I had had a clue (and if I had had more than a few weeks to build the theremins from when I actually got the order) , I would never have gone for the EPE front end!
note: So far, based on breadboard tests in far-from-ideal conditions, It appears that the best passive front-end in terms of linearity that I have ever played with (certainly as good as any passive* equalizing circuit I have built) is the "clone" derived from the Clara-min schematic using RCA inductance and capacitance values, and using an air-coil transformer wound on a EFD25/13/9 former, 450mm x 15mm copper tube for antenna, and a IFT wired as 1.2mH adjustable inductor in parallel with one winding of this transformer to facilitate trimming, and 70mH of 6300 series EQ inductors..
The above transformer has total measured inductance of 680uH, and the IFT is across the upper winding only.
* as in, no active electronics or frequency monitoring / correction circuit.
But I am cautious - The above is what I wanted to see - So I wont trust it until I have verified it!
