"Why did it play in the beginning?" - DOMINIKThere was sufficient capacitance between the antenna and the connector to sustain good voltage swing?
Sounds reasonable. Luckily there has been enough clearance with the variable inductor. Otherwise no problem: just saw off a little piece from the antenna.. gently..
